Atco Royale 24" Manual
I am restoring an Atco Royale 24" of 1970 to 1990 and I need a manual of this model. Who can help me or provide me with a manual?
I am member no.1222 from Germany
ha-jo-je@web.de
Thank you for your help.
Aled Wed, 08/08/2012
You don't happen to have the manual for the same mower but the 1982 model with the Tecumseh H60 fitted?
Would be much appreciated.
wristpin Wed, 08/08/2012
Shouldn't be a problem but as the one that I uploaded was pre-opc I would not have thought there would be much different unless you need one with BSF fixings rather than the later UNF model. In that case the main difference was in the cutting cylinder drive dogs and gears. If you can clarify this it will ensure that I upload the right images.
The ones I work with have a fuel tank mounted on the handlebars, a Tecumseh H60 engine and BSF fittings.
