Atco Standard 14" Cutting Blade Sprocket
I am in the middle of a restoration of an Atco Standard 14" Motor Mower (very exciting and my 1st old mower project).
I have dismantled most of the mower and all looks good, all quite original, but not got to the engine yet, last run in the 1970s.
However, I have noticed the sprocket on the Cutting Blade is quite worn on 50% of the teeth are very low compared to the rest.
See Picture:-
Its Part 4887 Sprocket - 10T from the Atco Parts List PDF.
I have a couple of questions if anyone can help:-
1) Does the Sprocket just pull off the hex shaft (with a bearing puller)..?
2) Does any one have a Sprocket spare or willing to sell..?
Any help would be greatly appreciated..?
Kind regards,
Ian
wristpin Wed, 09/07/2014
Don't have an answer to either question but if you enter Vintage Atco into a fleabay search you will find a trader selling a few Standard parts. They may be able to assist.
greensleaves Sun, 13/07/2014
Hi There  saw a few of these many moons ago  but scrapped them,anyway
to your question  the cylinder sprocket  is either  like suffolk  2 flat flanges
or screwed on could be left handed thread.If you look at the photo below sprocket
you will see the flat flanged section ,Hope this helps a bit.Heat it up
with a blow lamp etc  to remove.
topgunhorse Tue, 15/07/2014
Hinchy reports that his sprocket was removed using a puller.
I used a blow torch but was unable to shift it.
Hinchy's question to me now is, "has the heat damaged it?"
Anyone care to comment?
