Atco Commodore B20 cutter bearings
Rogeriwhittaker
Mon, 08/08/2016
Does anyone know where I can get replacement bearings for the above? The bearings I need are for the non drive side which seems to have a double bearing. I am currently restoring this old girl and struggling to get parts. Any advice or help welcome.
Many thanks for your help :)
The bearing at each end is
The bearing at each end is an RLS4. which is a standard item available from any bearing factor. I would consider using an RLS4-2RS which is the sealed version . As there is no provision on the machine for in service lubrication of the bearings there is nothing to be lost by using bearings with their own seals in addition to the machine's own.
One point worth noting is that the non drive end bearing should be installed onto the shaft tight up against the dirt excluding washers and the shoulder on the shaft and allowed to find its own position in the bearing carrier.
https://www.dropbox.com/s/wp6qn4owidtodrt/Atco%20Commodore%20cutter%20u…
