Bottom Blade
I have a part number for the Ransomes Certes 14 inch bottom blade GC 14 does anyone know if there is an updated part number. I have checked Ransomes and they still sell the 16 inch bottom blade MBA 7042. I’m will be soon going to get a new 10 cylinder made at Garfitts and I would also like a new bottom blade to go with the new cylinder, and I suppose the current bottom blade has lasted well since the mower was manufactured in 1934.
As Hillsider says, Garfitts
As Hillsider says, Garfitts are your most likely source; have you looked at their website? Just make sure that you specify your exact requirement eg shaver.
I telephoned Garfitts
I telephoned Garfitts yesterday but they have no records of the blade, it’s either send in old blade or send in the dimensions. The only problem I have is the true depth of the blade mine ranges from 2 and a ¼ of an inch to 2 and a 1/8 of an inch, I suspect to true depth to be 2 and a 3/8 of an inch. I will call again today because yesterday I did not specify a shaver.
Bottom blade now sorted with
Bottom blade now sorted with Garfitts I spoke to a guy who had worked at garfitts for 30 years knew all about bottom blade now on order.
Have you tried Garfitts for
Have you tried Garfitts for the supply of the bottom blade?
