Identify this Webb?
I'm hoping someone can identify the model of my old 18 inch Webb and date it.
I've owned it for about 30 years, and it was old and well worn when I pressed it into regular use. Eventually the original engine lost the little compression it had, so I found a replacement at the local tip. I bought an Atco from the tip shop because although the chassis was totally shot, the engine stood out as something special in decent factory black paint and an excellent compression. I wondered if it had been a replacement engine that simply outlasted the mower.
The 'new' Briggs and Stratton was more powerful than the original at 2.5hp and I had to modify the linkage to the drive shaft to make it fit. As original, the output shaft had a pulley wheel under the bent tin cover. You can see the slot in the cover where it was. I've no idea what purpose the pulley had. Any ideas?
A useful feature of the Webb is the cable operated device to disconnect drive from the roller. This means I can nose the mower into corners to cut those awkward areas. The clutch lever has a peg-in-the-hole feature to keep it pulled in and disengaged rather than a ratchet type lock.
The Webb is now back in action. It had stood for two seasons unused, but started third pull just with fresh fuel. You may spot a hand crafted wooden handle on the pull cord.... patent pending.
Good heavens! It could cut
Good heavens! It could cut hedges as well! I've never heard of this attachment, I must find out more. Thanks Wristpin. Any chance of a date on the mower?
Do you by any chance still
As I said, 1964 / 65 but do you by any chance still have the original engine? If so the Briggs Code Number will give the year, month and day of manufacture and this will give a rough indication of when the machine was made.
Thanks again Wristpin. I
Thanks again Wristpin. I never throw anything away, so I know the old engine is in the shed somewhere. I didn't know the number dates the engine, I'll look it up. And thanks arnk for the pictures. I learn something new every day. Not difficult when I start from a low level.....
I think that your machine is
I believe that your machine is a 1964/65 18"Standard Motor Mower model 250.
The slot in the shaft guard was possibly to accommodate a belt to another pulley on a bracket driving a Tarpin Heli-Strand flexible shaft and hedge cutter attachment.
