new here and trouble with my atco
Hallo first off all i live in belgium , and i love lawnmowers with a cylinder
i have one old sufolk and one atco balmoral 17 s
the atco has some troubles , when you start driving you have a KRRRRR sound coming i guese from the big cylinder on the left ore the big flyweal
it drives but when you lift the machine a bit up the krrrrr stops , hope you can help me with it
thank you
Kind regards
james Belgium
It may just be wear in the
It may just be wear in the roller and pinion bearings causing meshing issues but you should be aware that back when the Balmoral was introduced there was a meshing problem caused by chassis flexing which was addressed by the addition of a tie rod and two reinforcing plates. Hopefully your machine has either had the modifications or was built after they had been incorporated in to the new builds. The last service bulletin issued was, I believe, in 1996.
hallo thank you all for
hallo thank you all for answering
i believe the atco is from 1998 but i am not sure , will postthis night some pics from it , will open it up also
thank you
kind regards from belgium 20°c so far !!
Definitely sounds as though
Definitely sounds as though there is a problem with the drive pinion, enough I would say to justify further investigation.
I can't comment on parts availability in Belgium but there are companies offering parts via the internet here in the UK.
thank you , i let make some
thank you , i let make some noise , when it brakes down i will repair it, during the 1990-2000 mass of atco have been sold
if i not find the part in belgium, will contact then the forum to make sure i buy the right part
regards and greetings from belgium
There is an internal gear
There is an internal gear inside the rear roller, this is driven by a smaller gear through the frame side, this smaller gear and/or the large gear are damaged. It also likely to stop driving before long.
