Ransomes Marquis Mk4
Can anyone help with dating a Ransomes mower I've recently bought?
It's a Ransomes Marquis 18inch Mk4 with a BSA sloper engine.
The Regd. No. is DE 2972.
For interest the supplier stickers although badly scratched are still readable:
Supplied by H.N. RUMSBY & SON, ENGINEERS, Phone Bungay 54
Do they still exist I wonder?
Any help would be appreciated.
p.s. it starts first pull and runs beautifully!
Thanks - I'll follow up both
Thanks - I'll follow up both your suggestions and if I make any progress I'll post the results on the Forum. I can see there's a series of numbers stamped on the Sloper exactly where you described. I just need to clean the area up a bit so I can read them properly.
Steve
I've managed to get an
I've managed to get an approximate production date for the Marquis by contacting Meetens and Ransomes - so for anyone else with a similar mower the following may be of interest.
BSA Sloper engine: stamped 12C/BZZ/02/17388
Paul Child at Meetens told me that this was "one of the early BSA engines, early 1960s" and that I would "not harm it by using unleaded petrol"
Marquis chassis plate: Ransomes 18" Marquis Mk4 Regd No. DE2972
Ransomes advised that Marquis mowers with the DE suffix were manufactured between September 1963 (starting with DE301) and September 1967 (ending with DE5056).
Confusingly they told me that the suffix DE was used for the 20" Marquis and not the 18". Mine is definitely an 18" - the chassis plate says so and so does my ruler - so a bit of a mystery there!
So my best estimate is that my Marquis dates from around 1965.
Hope the above is of help.
No idea as to the precise
No idea as to the precise date of a Mk4 but have you tried Ransomes ? 01473 270000.
If you view the Sloper from the rear there is usually a series of numbers stamped into the vertical face of base of the engine casing. Paul at Meetens may be able to interpret them for you.
www.meetens.co.uk
Example
Info on Runsbys - http://discovery.nationalarchives.gov.uk/details/rd/e6e31fa8-2d66-4fdf-…
