Suffolk Colt/Super Punch 25A motor torque settings
Is there a workshop torque setting table/chart guide for the above motor?
I know the head is 12.5 ft lbs and the flywheel is 28 ft lbs I think, but what about the rest such as the big end, magneto end plate, sump, etc ?
wristpin Sun, 07/08/2016
Suffolk cast iron block 75 and 98 cc engines.
Points .018" *
Inlet valve .007"
Exhaust .015"
Plug gap .025"
Timing 22 - 24 degrees btdc
Head bolts 180" lb
Big end  bolts 130" lb
Flywheel 22' lb
* very early engines with "see saw " points .020"
Never seen a torque specified for the block to sump bolts  but I have seen the threaded boss pulled out of the sump !
goodgrass Mon, 08/08/2016
Thank you for that useful information.
I haven't a specification in inch pounds for a long time.
What do you think the estimated torque spec for the sump and magneto back plate bolts would be?
I would be quite easy to over tighten the sump bolts.
wristpin Mon, 08/08/2016
No official info for the mag back plate but the figure for the crankcase cover on th A98 and A114 alloy blocks is 100 " lb  . As for the sump I would say just pinch them up tight with a short spanner and check them when it's run a while.
Thanks for that, I will follow your advice.
I have a useful Haynes manual which covers this mower and engine, but the important information you have provided me is sadly omitted.
goodgrass Fri, 12/08/2016
I have often seen inlet 4 thou and exhaust at 10 thou quoted - is that incorrect?
wristpin Fri, 12/08/2016
I've never seen those settings for the cast iron block engines, only ever seen 7 and 15.
For the A98, 9 and 11 and for the A114, 6 and 10.
