Webb wasp decal
Hi guys and greetings from Melbourne
on on the weekend I brought home a Webb wasp which i would like to restore.
It has no decal on the mower but the catcher seems to indicate it is a late  mark 5. Could someone please confirm this, and does anyone has a clear image of the appropriate side decal? As I would like to make one up.
Thanks in advance
hillsider Tue, 17/11/2015
Hello and welcome to the Old Lawnmower Club,
Looking at the paintwork of your mower it looks though it is in its original paint with no sign of a transfer having been on the side cover. I am sure I have one of these buried in my store so I shall locate it and check what it has on it for you.
Give me a day or so and I shall post my findings.
wristpin Tue, 17/11/2015
Greetings also.
I too have a Wasp well buried in the shed but won't be able to get to it for a couple of days so see what Hillsider' comes up with and I will let you know how mine compares in due course.
Whether to restore or preserve is a personal preference and the subject of many long- running debates  but if the paint work on your machine is original I would consider preservation rather than restoration.
Cox11 Tue, 17/11/2015
Thanks gents, that would be much appreciated. The paint work is in great nick, but there are surface rust spots all over. Should I ignore these in the interest of preservation?
osbornecollection Wed, 18/11/2015
Hi I have this picture of a Mk3 didn't know if this would be any use to you.
the length is 25 cms x 13 cms high
Cox11 Thu, 19/11/2015
Thanks OC, I have access to that one here in oz. however, I believe my mower is a mark 5 and am going to do my best to keep it original.
This is is despite the fact I love the older series decals, particularly the catcher decal which matches the one you have posted
hillsider Sun, 22/11/2015
I have now unearthed my Webb Wasp and can confirm that there is definitely not a transfer on the chain case nor has there ever been one as the paintwork is original, interestingly the paint on my machine appears to be a lighter shade of green to that in your photo.
On my machine the rear roller has a cover over it that reaches forward to hide the thrower plate but it carries a transfer that states the model of the machine and that it a series 5.
Hope this helps.
Cox11 Sun, 22/11/2015
Thanks for that hillsider. I've now stripped mine and can confirm its the original paint also the model and serial number is stamped on a small silver decal on the left side panel. It does not state a mark/series
wristpin Sun, 22/11/2015
That's good then as I took a look at mine from a distance and it's parked the wrong way around and "impossible" to get at!
