J&P Maxee Lawn Mower
17 posts / 0 new
Triumph66
Hello,
i have an old J&P Maxee lawn mower which I salvaged (with the owner's blessings)  from a skip some 12 or so years ago. Since then it been in the back of my shed gathering dust and the like. I would like to rejuvenate the old beast but I would be interested to know where I can source spares. Does anyone have a grass box for example? Also I need at least one wooden handle from memory.
I will try and take a photo to ascertain what model it is and to remind myself what needs doing.
if anyone on here are restoring or have restored one, I would be interested to see theirs so I can see what I need to do.
Many thanks
Andrew
hillsider
hillsider's picture
A photo or two of your mower
A photo or two of your mower would certainly help us to confirm the identity of your JP mower, if you look on the frame of the mower usually on the left side near the front roller you should find a serial number. If you post that here we may be able to tell you its build date.
Re spare parts I am not aware of any one who is breaking JP machines for parts but let us see what you are dealing with and things may become clearer.
Triumph66
Thanks Hillsider. I must drag
Thanks Hillsider. I must drag it out of the shed and take those photos to reacquaint myself with the lawn mower.
Triumph66
At last I managed to drag out
At last I managed to drag out the old J&P mower from the shed.  I apologise for the state of my lawn as for the last 4 months we have been besieged by builders who have just completed our extension. I will give the mower a quick clean tomorrow but can report that it rolls freely which is a good omen.
Triumph66
Photo of J&P Maxee?
Photo of J&P Maxee?
Triumph66
Photo of Maxee?
Photo of Maxee?
Triumph66
Logo of J&P. My plan is to
Logo of J&P. Just out of shot is a horizontal bar near the top between the two handles.
My plan is to strip and re paint it in the original green colour with new wooden handles and rollers plus Decals where appropriate. If anyone got a grass box I would be very interested.
Triumph66
I have taken some more photos
I have taken some more photos of the mower after I gave it a quick clean and degreasing. I have liberally sprayed all the nuts and bolts with WD40. I could not find any serial # details on the casing unless it has been painted over. I have taken off the chain cover and see that it is an olive green colour.
Triumph66
Triumph66
Photo of the horizontal bar
Photo of the horizontal bar between the handles
hillsider
hillsider's picture
From what is visible in the
From what is visible in the photos I am not at all sure that your Mower is a Maxees! hopefully you will find some letters and numbers stamped into one of the side plates that will help us to identify it.
Triumph66
Hillsider, I am not sure why
Hillsider, I am not sure why I thought it is a Maxee model but I don't think it is from my very rudimentary research in this make.
Hello
Hello
Done a bit of checking up for you, it is a very early Maxees possibly 1938-1940 when they were first introduced. The serial number was stamped in a different place to later models, it should be on the top crossbar to the right of the centre hand-wheel as you look from the front, it will be very small & probably start with a G followed by two letters & some numbers. Be careful not to grind it away, gentle clean & very fine abrasive should do.
Do you have the grass box, it would have had wooden sides like the later JP Super.
I do have an instruction book for this model which was referred to as the 'Pick-A-Back' lawnmower because of the interchangeable cylinders, when one was being ground you simply slipped in the spare.
Let me know if you find the number & we can then get an accurate date.
Triumph66
Hello Clive,
Hello Clive,
Many thanks for identifying my lawnmower. So it is a prewar example. I wonder what stories it could tell if it could speak! Anyway, I have just given a very quick and light sandpapering as suggested but could see nothing. I will try again this weekend. I am afraid I have no grassbox with it unfortunately. If anyone got one spare, I would be very interested. I am interested in the owners' manual if it is available?
Thanks Andrew
Triumph66
Here is an advert of an early
Here is an advert of an early JP Maxee that I have found.
Here's some more ad's from
Here's some more ad's from 1939
Triumph66
Great adverts with so much
Great adverts with so much nostalgia. I hope this weekend I will have a chance to examine my JP and find that serial number to ascertain the date.
