ATCO rotary mower with Aspera engine - need a carb...
I need to get hold of a Dellorto 2013 carb for my ancient ATCO rotary mower, it's the one from the late 1960's.
Are there any carbs available? - can you get a replacement that will fit/work?
Does anyone know where I can get hold of one???
Thank you.
Laine
Lee Smallwood Wed, 15/04/2020
Hi Laine, I'm adding a photo of my Atco rotary, if it's the same motor I presume it'll have the same carb, but happy to take further photos if required. I'm currently advertising this mower for sale and getting a lot of interest, I've got it up for £45.00 but can move on the price, it runs albeit not for a while, the air filter needs attention and there is a slight chip on the plastic edge. Not sure where you are and if you'd be interested.
wristpin Thu, 16/04/2020
What mower do you actually have? I have visions of the 4-stroke  wheeled or roller machines - red and cream or green and cream - not the airborne two stroke?
Are you missing the complete carb or is it that you have an "unsolvable" issue with an existing one?
New ones are available - at a price! Several versions of the 2013
https://www.dellorto.co.uk/shop/dellorto-industrial-carburettors/complete-carburettors-dellorto-industrial-carburettors/r7352-fhcd-20-13/
https://www.dellorto.co.uk/product-category/dellorto-industrial-carburettors/complete-carburettors-dellorto-industrial-carburettors/
laine Thu, 16/04/2020
Hi - thank you for getting back to me.
It is a green and cream model, 21" cut with the 'automatic' height lever on the right-hand side.  I assume it is from the late 60's?
I have a carb on the mower, but it won't start - I have fitted a new coil and can get it to fire/start straight away with petrol down the plug hole.  I have cleaned the carb but can't get the main jet out.
Any advice would be very welcome.
Laine
Can’t get main jet out. Not unusual . It needs a hollow ground parallel tip screwdriver and often heat. How good or bad is the slot? If it’s chewed up life gets interesting but all is not lost.
