Blade Sharpening
10 posts / 0 new
dunnes2002
Last seen: 10 months 2 weeks ago
Blade Sharpening
Morning,
I'm currently very close to finishing my Atco Standard 16"rebuild which is in desperate need of sharpening. Does anyone have any recommendations for 'sharpeners' in the Leeds/Yorkshire region?
I have been quoted around £50 - £70 pounds but it makes me slightly nervous when they have never hears of an Atco Standard!
Mike
Last seen: 35 min 59 sec ago
That seems a bit expensive
That seems a bit expensive but if it's a "main dealer" who has laid out the thick end of 20k for an all sing and dancing precision grinder, perhaps not. Around here (Kent) £40 will get a 20" cylinder ground and perhaps the bottom blade skimmed as well. While on that subject there's no point in grinding the cylinder and not the bottom blade, even if it's a new one which may have been ground on a magnetic surface table but will conform to your sole plate when screwed on.
As for not having heard of an Atco Standard, if the man (of either gender)  operating the grinder knows his/her job a cylinder is a cylinder regardless of what it comes out of.
Chris G
Chris G's picture
Got a 17" cylinder and bottom
Got a 17" cylinder and bottom blade done for £25 - including painting the cylinder!.
It was a good job too so £70 does sound expensive.
I would add, that was in the Yarmouth area so not much help if you wanted to drop it off...
dunnes2002
Hmmmm i guess i need to make
Hmmmm i guess i need to make a few more calls this week. One of the places i haven't managed to contact yet and maybe favorite,  looks to be working out of his garage turned workshop (Google maps) . I'm hoping he is very experienced and reasonably priced
Sounds promising - beer token
Sounds promising - beer token job maybe ?
dunnes2002
Jackpot, rang a local
Jackpot, rang a local business to where i work, quoted £25.
Gave me a lot of confidence over the phone too as he explained the process, as my cylinder shaft has lost it's centre point. Will be taking it down once i work out how to remove the bottom blade!! The screws look a little ceased!
hillsider
hillsider's picture
Last seen: 2 hours 32 min ago
The bottom blade needs to be
The bottom blade needs to be attached to it's carrier for grinding in order for the blade to be true, so unless you are fitting a new blade to the carrier you can leave the screws alone and save yourself a job.
dunnes2002
I did think it was way little
I did think it was a little odd was planning to take it in attached just in case he meant the big frame rather than the bottom blade frame. Lost in translation confusion! Will find out next week.
Gave me a lot of confidence over the phone too as he explained the process, as my cylinder shaft has lost its centre point. Will be taking it down once i work out how to remove the bottom blade!! The screws look a little ceased!
As Hillsider says, if your bottom blade has enough "meat" on it to take a skim, leave it attached to the sole plate - bottom blades whether existing or new must be skimmed attached to the sole plate that they are going to run on.
Grinding cylinders between the countersunk centres in the shaft is a "last resort" for when there is a need for a bearing size that the operator does not have. It's far more satisfactory to grind with the cylinder in bearings that are similar to the ones that it runs in. I've ground many Atco Sttandard cylinders over the years and can't recall any issues with bearing sizes  -  RLS5 with a radiused outer race, I think, but it's been a while!.
A bearing for most occasions, more "specials" in the drawer!
dunnes2002
I could definitely have done
I could definitely have done with that selection of cups. All in all took about 6 weeks for my blades to be sharpened, he did seem a good knowledgeable person at the start!
The excuses included sickness (fair enough being a sole trader), getting married, too busy, won't fit, then he sent to his mate... who he couldn't get hold of for long periods of time. But then they were done and they look great, onto this weekend and the first cut
