cork clutch pads
I read an article by olcadmin on 28/04/2015 about rejuvenating the corks on petrol taps because they had shrunk. The idea was to 'cook' them slightly with a gas torch so they would expand. I was wondering if the same principal could be applied to the cork inserts on clutches like Ransomes Mercury and Auto Certes and Qualcast 16 etc.?
I have seen a blow torch used
I have seen a blow torch used to burn oil off of clutch corks but not so sure about using heat to expand the cork on a fuel tap, if I tried that it would probably just ignite it.
I have however suspended a fuel tap in a petrol can to bring it back to life after it had dried out but not very safe to have a clutch plate soaking in an open container unless you can use a safer liquid than petrol.
Can't recall the cooking with
Can't recall the cooking with a a gas torch procedure but I know that some people boil the tap plungers to expand them. However it's never worked for me!
