Hayter Twentyone 1985 (Osprey)
This machine (the Twentyone) is my workhorse for a couple of acres grassed rough bank; the only thing that is better is a flail mower. I have two issues to resolve at the moment.
1. After 'no mow May', I was cutting through 2ft grass and over the last few weeks I seem to have managed to get the grass wrapped around the rotary blade, to the extent that even after clearing as much as is possible with a hacksaw blade, the stiffness of rotation stops the engine from starting because of the friction between the drive belt and pulley. Before stripping it down, I wanted to find a diagram that showed the components of this part of the machine, but have been unable to find any diagrams for this mower. Any assistance much appreciated.
2. I noticed that of the front wheels was 'floppier' than usual and the red plastic cover on the inside of the wheel had become dislodged. On dismantling the wheel I found that there was only a bearing on one end of the axle, although both ends appear to have provision for bearings. Again, I have been unable to find a source of information to confirm or a supplier for such bearings. I think that the Hayter Osprey wheel assemblies are the same.
Thanks, wristpin. Pulley nut
Thanks, wristpin. Pulley nut looks like anti-clockwise to undo?
https://www.dropbox.com/s
https://www.dropbox.com/s/mfw73el5kq22gkn/Hayter%20Osprey%20and%2021%20…
Nut off, pulley off, remove key from shaft and with a bit of encouragement the shaft and cutter disc will drop out (I think!!) Nut back on before hitting it! I vaguely remember that the cutter bearings were an unusual but available size.
I think that the wheels from a Hayterette that come complete with bearings, will fit.
