How do I remove the rotary blade plate
I need to remove the cutting blade plate on my Nash Boadicea, I have removed the retaining nut (though it still shows it in position in the photographs). Will a gear/clutch puller be required or is it threaded on? I am unable to find a parts or owners manual for the machine.
wristpin Wed, 15/04/2020
Someone may know for sure but guessing, it’s a choice between a taper or a keyed parallel shaft. Either way warm it up ( alloy?) and put careful pull on it with a three leg puller. Maybe warm it more while it’s under tension.
djg745 Fri, 17/04/2020
Thank you Wristpin.
I have been able to remove the plates from two machines using heat and a three legged puller. I am now faced with a tapered shaft with a Woodruff keyway, no remains of any Woodruff keys and no apparent keyway on the plates. Could there never have been a Woodruff key or I am I missing something?
wristpin Fri, 17/04/2020
Has the disc got a keyway in it?  If it has I think that there’s a fair chance that there was once a key. Perhaps someone has a Nash illustrated parts book .
djg745 Sat, 18/04/2020
Unfortunately I have not been able to track down a Parts manual for the Nash.
I attach some photographs, showing the keyway on the shaft, but no apparent keyway on the plate. There is a slightly lighter keyway shape on the surface of the plate inside the aperture but I assume that is from where there hasn't been any metal to metal contact coinciding with the keyway on the shaft.
wristpin Sat, 18/04/2020
With no corresponding keyway in the plate the one in the shaft is surplus to requirements.  possibly making use of a shaft used in a different application.
Thank you, the JAP 34cc engine was used on several other machines as well as other applications I assume.
