Ransomes Ajax Mk3
2 posts / 0 new
135sport
Last seen: 11 months 2 weeks ago
Ransomes Ajax Mk3
Hello All,
I am new to the world of old mowers, and I have recently treated myself to a Ransomes Ajax Mk3, that is in need of some use and TLC.
The big issue I have so far with it is that both the front roll carriages need replacing or repair. One side is just cracked but the other side is in 3 pieces. I have tried to have them welded, but I believe they are a form of Mazak or Zamak, so the result is not going to last or look particularly good.
Do any of you have or know anywhere where I can buy a pair of replacements? I expect the replacement will be used parts, so that is not a problem for me.
Thank you for any help you can provide.
Regards,
Christopher Hulme.
Last seen: 13 hours 14 min ago
Hello Christopher
Hello Christopher
Welcome to the forum.
I have numerous Ajax's around & should be able to sort the spares you require, have emailed direct.
Clive
