Ransomes Ajax Mk4 cutter bearing
Hi all,
Just wondering if anyone can recommend where to get a Cylinder Blade bearing for a Ransomes Ajax Mk4 from? new or secondhand?
The parts diagram shows the bearing "itself" as RL5? I only need the one for the drive side looking at it at the moment.
For info - I removed the bearing and housing complete, the cover is off, but the bearing is still in the housing - I assume the bearing just knocks out of the housing?
Kindest regards,
Kevin
hortimech Fri, 17/04/2020
It is a standard bearing and it also has the ID of NLJ 5/8, you should be able to obtain it from any good bearing supplier. I would also replace both of the cylinder bearings.
kbonney88 Fri, 17/04/2020
Hi Rowland, and thanks.. been doing some digging and found a post on here about them too.
Have also been looking online for the bearing, found a few suppliers.. so - will sort them now..
thanks again for replying..
Kindest regards,
Kevin  :)
