Qualcast B1
Had a bit of fun with this one. The blades still had a good edge on so I opted for a clean-up and repaint. The colours matched reasonably well, especially the red. For this I used Ford Carnival Red and Ford Olympic Blue. The transfer was obtained from the club, thanks to Colin for the quick delivery.
Not sure how or if these can be dated but on the blade carrier is the number 62. Would anyone know if this is a date of manufacture?
Hedley Sun, 28/04/2024
Morning Chirpy,
I was planning to use it. I've discovered the advantage with side wheels on longer tufts that my cylinder mowers just flatten with the front rollers. It will only be used occasionally but its ready when I need it.
RansomesRob Sun, 28/04/2024
Hi Hedley. Your B1 looks amazing. Having read that you find your cylinder mowers flatten the longer tufts of grass, you might a forum topic from 2020 interesting? If you type into the Search Site box.....Front roller laying grass down problem.....you will find the discussion. Cheers. Rob
chirpy999 Mon, 29/04/2024
A push mower is all most people need if you have a smallish garden. Ive got a Webb 12hr and find it a great little machine . You might need a bit more power for say a early cut after winter but thats about it I think.
Hedley Tue, 30/04/2024
Thanks to all for the advice. I'll have to keep a look out for a set of front rollers and bar from a Mk5 Ajax. I could swap these over on my Mk4 and just set up with the smaller outer rollers. Although, I do enjoy deciding which mower to use when cutting the lawn, it's interesting to compare different manufacturers and models.
RansomesRob Tue, 30/04/2024
Hi Hedley. I also like to compare the different manufacturers and models when cutting our 2 small lawns. Back in 2017 I got my first 'old' push mower and that was me hooked!! I now have 13 push mowers and there are still plenty of models that I would like to try, but sadly, there is no more room in my shed for anymore!  Cheers. Rob
