43sl cutter bearings
jarrett
Wed, 03/04/2024
Hi all, Got given a 43s 17inch cut mongrel machine, it had a very early iron engine fitted which has may have seen better days so removed that and started stripping down and now need cutter bearings and the felt pads, the bearings i removed may be ok with repacking but as it is apart i will replace, will a bearing outlet be able to match these up? although i will try and get the sealed type the markings on them are Japan, smt, r10.
From memory, I think that…
From memory, I think that they are more commonly known as EE5. If you run that number through the Simply Bearings site it will give the dimensions for you to compare.
