Atco b24 no drive nor cut
Cbyatt
Wed, 16/08/2023
All was fine, mowing along and then one time I let the clutch out after turning around at the end of a line….. nothing. No spin to the blades, no drive. Clutch lever still has tension …. Anyone warn me as to what I am looking for when I open the clutch cover box?
Probably that the roll pin…
Probably that the roll pin holding the drive square to the main shaft has failed. pts 20 and 21. From memory the original pins were 5mm but was upgraded on later machines to 6mm. We used to replace the standard roll pins with the stronger Spirol pins.
https://www.dropbox.com/scl/fi/0rd3qqiz3d6z8wwbomre6/Atco-B30-and-Royal…
