Ransome Ajax Spring for pawl required please
moorcroftman
Thu, 08/12/2022
Can anyone find and spare one or two of these Springs for the pawl on a Ransome Ajax please ? Part no. LK184.
Thankyou for replying. Good…
Thankyou for replying. Good idea ! I'll get some.
Best wishes
David
Hello - You could make your…
Hello - You could make your own pawl springs! I bought a length of "Spring steel strip coil" from eBay. Type "Spring steel strip coil" into the search function of eBay and you will see what I mean.
I made a couple using the original pawl spring as a guide. I couldn't make the exact shape but it did work. With more practice you should be able to make one to the exact shape. However, the length of spring I have has been in my shed for a couple of years and shows signs of a little surface rust. I guess this is because it's been exposed to the elements but once fitted into the lawnmower it would be protected by the grease.
