Suffolk fabric wrapped coils
4 posts / 0 new
suffolkalan
Last seen: 1 week 2 days ago
I started this new thread as the information would have got lost in my 'dating a Suffolk engine' post.
Being faced with an open circuit early fabric wrapped ignition coil I searched in vain for a secondhand working replacement and I didn't want to purchase another engine for spares.
I obtained locally a later Wipac coil/lamination assy for £20 with a view to making it work.
I dismantled my original lamination assembly by removing the rivet heads and punching them through, the later stator pack is a fair bit slimmer than the earlier type and I found 12 sections would fill the coil aperture but was too wide.
I cleaned the surfaces of the laminations and lacquered one side to insulate them from each other once dried sufficiently they were riveted together to make the stator pack, the centre  was  machined down to a width to slide into the new Wipac coil. A new spring steel retainer was made from an old recoil spring.
Sufficient to say I know it was a fair amount of work but I am glad to report that my new assembly gives a nice spark!
Result.
Alan
Last seen: 2 hours 19 min ago
That's a good mod or what I
,That's a good mod or what I belive is now referred to as a "hack"! I see that you have even managed to eliminate the condenser by using a coil with the encapsulated one.  I'm not sure that it's necessary to lacquer between the laminations; when I'm asked to test "naked" coils I just put a bunch of wire nails through the centre to provide the "soft iron core".
Chris G
Chris G's picture
Last seen: 1 week 5 days ago
Very clever idea, well done
Very clever idea, well done and looks well done!
suffolkalan
Thanks for your comments!
Won't start though!
Got good compression and spark but only managed a few firing strokes and the exhaust smoke is very white in appearance? Almost like it's running on paraffin!
Suspect a carb problem although it has had a proper dismantle and clean. Such a simple device!
Alan
